Back to documentation index
English Русский
HobDrive Widgets for Android
The HobDrive Android widget displays a selected sensor on the home screen. It uses the same rendering system as the app, can be resized, and keeps separate settings for every widget instance.
This feature is available on Android only. System command names vary slightly between phone, head-unit, and launcher vendors.
Adding a Widget
  1. Touch and hold an empty area of the Android home screen.
  2. Open the system Widgets picker.
  3. Find hobDrive Sensor Widget and drag it to the home screen.
  4. Android opens Configure Widget.
If the widget does not appear immediately after a HobDrive update, restart the launcher or device and check the picker again.
The Configure Widget Screen
Select Sensor
Tap No sensor selected under Select Sensor. In the list that opens:
The button then shows the sensor name, and the Preview area displays its appearance. Save Widget remains disabled until a sensor is selected.
Update Frequency
The Update Frequency list contains:
A shorter interval provides fresher readings but uses more resources. For values that do not need second-by-second updates, choose 30–60 seconds or on-demand refresh.
Preview and Size
The preview shows the widget styling before you save it. After adding the widget, resize it in the normal Android way: touch and hold it, then drag the resize handles. HobDrive redraws the content for the new width and height.
Optional Custom XML
Custom XML (optional) is intended for experienced users. It replaces the standard sensor presentation with a custom HobDrive layout. For example:
<item id="Speed" size="large"/>
HobDrive validates the XML and refreshes the preview as you edit it. Leave the field empty to use the standard presentation for the selected sensor. If the editor reports an error, correct the XML before saving.
See Layout Format Specification for available elements and attributes.
Saving and Using the Widget
Tap Save Widget to finish, or Cancel to discard the new widget.
Tap behavior depends on the selected frequency:
You can add multiple widgets and give each one its own sensor, frequency, size, and XML.
Reconfiguring an Existing Widget
HobDrive supports widget reconfiguration. Usually, touch and hold the widget and choose the launcher’s Configure, pencil, or widget-settings command. If your launcher provides no such command, remove the widget from the home screen and add it again.
Removing a widget deletes only that widget’s settings; it does not delete HobDrive data.
If the Widget Has No Data
